1927 super six Hudson Horn
Unknown
is someone know how to remove the horn butto from the steering , i dont see any screw or clip and doesent want to breake something.
Thank you. Robert
  • bent metal
    bent metal Senior Contributor
    If you don't get any response, I'll find out for you. I need some '27 stuff. Got any extra parts?
  • Geoff
    Geoff Senior Contributor
    The top bezel around the horn button should unscrew, and come off with the horn button. You cannot of course use any tools on this or it will shatter, but it should be able to be removed by gripping with fingers okay.
  • The top bezel around the horn button should unscrew, and come off with the horn button. You cannot of course use any tools on this or it will shatter, but it should be able to be removed by gripping with fingers okay.
    Thank you very much , it as worked very whell, a little hard to unscrew but by hand
    i have got it !
    Thank's again.
  • [Deleted User]
    edited April 2011
    When removing the button or replacing it use one of those rubber cap grippers used to open just about anything that has a screw on lid I have used them for years.
    Just a round rubber disc very thin but it is amazing how it helps you get a grip!
    Bob Hickson
