Question re water temperature
Unknown
edited June 2011 in HUDSON
I finally got my 54 Special with the rebuilt 308 engine out for a short test drive. My concern is the water temperature. I let the engine warm up then took a spin around the block two times. The temperature indicator gauge was at a tad past the halfway mark. Is this typical for a new engine? When it is broken in where will the indicator normally rest?
The water pump and thermostat are new and the radiator was full.
Thanks for any feedback,
Doug
  • Marconi
    Marconi Senior Contributor
    Sounds like things are about right, when engine is broken in it should run a little bit cooler. Between 160 and 190 should be fine, it depends on what temp your thermostat is.
  • All Hudson temperature gages have no temperature indicator on the dial. Just marks on the dial. You would have to buy a temperature ray gun. A digital unit that can tell temperatures on any part of the block, raditor, etc. A tool that should be in everyone's tool box. Plus you can take it with you and check temperatures while on a trip. Good luck. Rich
  • MY 54 Special runs just at or slightly above the center mark. I have a 180 degree t-stat.
    Bob Hickson
  • Marconi
    Sounds about right. The way to get an accurate reading is to get one of the infrared guns and check temps with it. I just got a flyer from Harbor Freight last week and they've got one for around $30.00!
  • THank you guys. Thought I might have a cooling problem but apparently it is in the norm.
    Thanks again,
    Doug
