Trunk Lock
drivergo2
drivergo2 Expert Adviser
Iam gunna bite the bullet, and drill the lock out. I dont want to but no other way, Was going to go thru the backseat but there is a rats nest the size of alaska in there. Whats the best way ,Drill that small pin out on top the lock itself ? I have no Idea. Any advice ?? Thanks John:unsure:
  • 54SuperWasp
    54SuperWasp Expert Adviser
    When I was young and trying to fix things on my car, brakes for example and the small springs were snapping everywhere, my father used to say: "Michel! Come and sit and have a beer with me! You'll work it tomorrow! The day after, all was getting well! R.I.P.Dad! ( Would have been 99 tomorrow by the way). This is the best advice I can give you while you wait for the other ( and better) experts.
    Michel.;)
  • drivergo2
    Your Right, Going to the store now:cheer:
  • Unknown
    edited July 2011
    I thought I took the glove box door lock out and took it to a locksmith to have another key made, which fit my trunk lid. Maybe I got it wrong, but someone knows how this works. Isnt the ignition lock key and door key the same?? Good luck, Bob P
  • dave s
    dave s Senior Contributor, Moderator
    You are right, Bob. Glove box should match the trunk lock.
  • drivergo2
    THANKYOU Thats great to here, Save alot oftime and work. John:)
  • the glove box uses the same key as the trunk on my 52 hornet, hope that helps
