'54 308 Carter Carb fuel inlet thread pattern?
All the Hudson carbs I've seen, from '36 on up, have had a 1/8 NPT in the bowl cover.0
Might have been cross threaded in the pot metal. I will get the magnifing glass out and try a tap to clean it up.0
All Carter Carbs are 1/8 NPT threads on the bowl cover, 1932 to 1954. You will have to find a new cover. Need tag number to get the correct bowl cover, or the number stamped on the base where the gasket goes. I may be able to help you. Walt.0
- 612 Vehicles
