gas tank pickup line
Edwardjohnsr
The intake tube at the top of the tank on my Hornet ends in a threaded connection with a flare nut. I'd like to replace the flare nut with an elbow to avoid a sharp bend in the line leaving the flare nut. Does anyone know what kind of an elbow could be used at this location?
Thanks
Ed
Thanks
Ed
Ed, The only thing I can think of is to try a plumbing supply, or a hardware store. I know what you are talking about. If I'm not mistaken I cut my line and put in an electric pump. If You do this (cut the line) You have to run a ground wire from the tank to the body to achieve a ground so the gauge will work.
Bob Hickson
PS..Just had a thought try a welding supply. If I remember correctly some of their fittings look similar...wishing you luck...0 -
Are you worried about buggering it up when wrenching on it, or for flow?
I believe Speedway Motors (www.speedwaymotors.com) carries a selection of 45° reverse flare fittings.0 -
You should be able to get all the fittings you need from Ace Hdwe., or what ever you've got near you if it's a GOOD hdwe store.0
I simply ran a one piece 5/16" fuel line which I bent with a tube bender, which gave it a broad 90 deg. curve. Instead of fittings I secure it in the bracket with grommets.0
Thanks for all the suggestions. Here's my final configuration:
Short peice of 5/16" brake line using the original tapered flare nut. Then an adapter for 5/16" compression to 1/8" pipe thread. Then a 1/8" npt elbow to make the 90 degree turn. This is a little more "Rube Goldberg" than I would have wanted but it works.
Again thaks to all for the input.
Ed0 -
Hey Ed,
I have been working on re doing a fuel return line on my 36T and got all my fittings from www.McMaster Carr.com. They carry EVERYTHING!
Good luck,
Jeff0
- 612 Vehicles
