Water jacket cover
Unknown
edited October 2011 in HUDSON
Hi
Found out today that the water jacket cover (initially thought it was a valve chamber cover plate) on my 40 is rusted through. Does anyone have such a plate?
(I hope I have the correct part name here - but see attached photo - the plate on the block)
Thanks
Dewald
  • Huddy42
    Huddy42 Senior Contributor
    This is the water Jacket cover.
  • hudsontech
    hudsontech Senior Contributor
    edited October 2011
    Back in the day when Art Adams was editor of the WTN he put a center fold in each WTN in the form of technical bulletins.
    These have been put online - there is one there that shows you how to make a new baffle plate. if you need that piece. Go to:
    http://hetclub.org/burr/other/lit-other.html and click on Hudson Technical Bulletins, Vol. 1 - the one you want is TS 84-2. Sorry about the quality of the reprint, the original wasn't all that great but it is useable.
    On the other hand, the cover itself is a different matter.
    Alex Burr
    Memphis, TN
  • I should have one - its the six cylinder isn't it?
    Roger
  • Marconi
    Marconi Senior Contributor
    If all else fails, try Jason @ Vintage Coach, 8to 5 Tues to Sat. 909-823-9168. He has NOS ones in stock for the 6 cyl engine.
  • Unknown
    edited October 2011
    Hi there
    Update on the cover plate.
    After taking the plate off, I noticed the real rust damage. The baffle is completely rusted through. As can be seen from the to photos, there is a rust crack almost right around.
    Also, here is a photo of the rust on the inside before I started cleaning it away.
    Thanks Alex for the bulletin - I will defenitely use it to build a new baffle plate.
    Dewald
  • oldhudsons
    oldhudsons Senior Contributor
    you might save yourself a lot of time by just buying an NOS one; if not Jason also try Al Saffrahn who I'm sure has good used ones as well as NOS
  • oldhudsons
    I'd also suggest that after you've got your repairs done & cooling systems flushed & cleaned out that you add water soluable oil to your new clean water - it will prevent future rusting & is avail. in auto parts stores.
  • At the national in OKC I bought a new stainless steel replacement from Charlie Harris for my 254 8cyl. I believe he had them for the six's also,
    Roger:unsure:
  • SamJ
    SamJ Senior Contributor
    From your photos it appears that the baffle is completely missing. There should be a plate on the inside with three round holes in it. Any or all of the suggestions above should result in your obtaining a good water jacket. ;)
  • True, the baffle plate has completely rusted away.
