Vin number for 35 Terraplane
The vin # should be stamped on the outside of the frame rail on the passenger side of the car right around the front door. It is also stamped on the back most frame rail below the trunk. On my '36T it is also on both front and rear axles! I assume that your '35 should be the same?0
35serial number is stamped in the top of the frame rail, I forget which side but it's right in front of the body mount. The ones I've seen have been lightly stamped so you need to clean the frame rail 'real good' to see it.0
On my '34 Terraplane the confidential serial number (or "hidden number" or "secret number") for law enforcement verification of stolen vehicles is located on the pass. side frame above the rear of the front spring mounting. It is also on the front face of the front axle on the right side. I expect one also on the rear axle but have not seen it as yet.0
