6V Alternator
they make a conversion kit as well--
http://store.alternatorparts.com/10si-series-6volt-positive-ground-alternator-conversion-kit.aspx
If you want a 6 volt 53 amp output, you need to start with a 105 amp 12V alternator.0 -
http://www.alternatorparts.com/10si-all-in-one.html
This site has both + and - 6volt Alternator. Brent0 -
What BHLHet says:
Quick Start #D110sisE6v53 thats 53 Amps
1 wire to Bat on Voltage Reg, and Bat to Battery, or starter Solenoid. Works like a champ. They even have mounting hardware. Negative ground.0 -
Thanks Guys!
JC0 -
Just looked at the web links you kindly provided.
MUCHO thanks - just saved around $80!!
Jon0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
