35 Hudson engine color
The best performing and correct color I've found is Duplicolor 500 degree engine paint in Aluminum color ... available at most auto parts stores. Clean the block well with kerosene or other solvent, then wash with soap and water. Then wipe down with POR-15 Metal Ready or similar etching solution that will leave a thin coat of zinc phosphate. Spray two or three light coats of the Duplicolor. For accurate original appearance don't put it on too heavy ... you should still see the texture of the cast iron surface.
The "sod trays" should be black.0
- 115 Hudson 1916 - 1929
