side mount grommets needed
Dave, Try Restoration Specialties in Windber, Pa. right in your neck of the woods. If they don't have them they could likely order them from Au-Ve-Co.0
Dave, you might try Rod Hudson at Xkrodhudson@bellsouth.net (delete the X before sending). At one point he was offering part number 102488, the sidemount bracket grommet at the cowl or fender.0
Thanks, Jon. I finally got answer from Rod and he has them.:)0
