37 running board fitment
Ive used regular Fender welting. Actually I prefer the stainless bead welting only available at Dennis Carpenter in Charlotte....0 -
I have the Kgap running board mat to glue on soon. The metal running board has deep grooves so if not filled I can see high heels going thru the mat. Curious what others have done also. Perhaps riveting another sheet of flat steel over the top? Kgap also provided some rubber 90 degree edging. Not sure about this either. Appreciate some comments. Thanks, Barry0
OK, I thought the mat would come with grooves so as to form in place.
What about a spray on bedliner type material?0 -
barrysweet52 wrote:I have the Kgap running board mat to glue on soon. The metal running board has deep grooves so if not filled I can see high heels going thru the mat. Curious what others have done also. Perhaps riveting another sheet of flat steel over the top? Kgap also provided some rubber 90 degree edging. Not sure about this either. Appreciate some comments. Thanks, Barry
Hey Barry,
The 90 degree edging goes between the outside strip and the running board with the lip on top facing out. Hope that helps!
Jeff0 -
No welting was used in Hudson bodies. It only traps water and enhances rust formation0
I used a thin clear nylon washer between the running board and where it bolts to the front and rear fenders. It is unnoticable, doesn't trap water and prevents any rubbing. :cheer:0
barrysweet52 wrote:The metal running board has deep grooves so if not filled I can see high heels going thru the mat.
G'day Barry. Easiest solution is just to wear your flats rather than heels :P . Other than that I would be thinking of a polyester body filler (bondo) or a DIY epoxy filler, ie start with a basic epoxy resin and load it with a filler powder of your choice. Epoxies generally have good adhesion to steel.
Maybe cruise the aisles of your favourite ironmonger and look at the different gap fillers, caulks etc available to the building trade.
Does anyone know if the original mats were moulded to fill the grooves in the steel running boards?0
- 612 Vehicles
