Stepdown Aerial fastening - dash
I think I have found most of the components for the aerial connection that goes down the front of the windshield on my '50 Pacemaker.
I have two questions -
I have a shaped bracket that seems to fit sandwiched under the dash that the base of the inside aerial secures to. It looks as if there should be a long screw that goes through the front of this bracket to secure it to the bulkhead but there seems that there should be a spacer also. Is this correct? Does someone have a picture or diagram of how it should be assembled and to maybe identify the part I may be missing?
Secondly, I assume the wire from the roof aerial goes on top of this inside aerial. Is it just held on by a tight fit? and should this join have a protective sleeve over it (I am guessing maybe yes)?
Just another one of my many queries to come, thanks all.
Alistair
NZ
Alistair
NZ
Alistair, The base plate for your antenna is mounted to the forward dash valence by a single long screw as you have observed. The bracket joins up the two dash valences as a coverplate. If your car came with an antenna , then there will be a hole in the coverplate without a cover plug. If no antenna came with the car then that plate has a plug or there is no hole whatever. (in which case you have to drill a hole) The hard wire antenna comes down from the roof in back of the mirror bracket and has a plastic base that sits on top of the coverplate hole. This plastic base has a threaded part which goes through the hole and connects with the antenna lead coming from the radio itself. The opposite end of the hard wire antenna has a connector going to the antenna mast itself. This is a soldered connection onto the antenna base while the hardwire part has a push connector attaching it to the antenna mast. If you can get a copy of the 1951 "A" series shop manual, the complete layout is in section 6-37. Good luck.0
This may help,
Roger0 -
Many thanks guys, just what was needed!
Alistair0
- 115 Hudson 1916 - 1929
