FUEL PUMP 308 HUD
Unknown
edited June 2012 in HUDSON
IS THERE AN AFTER MARKET FUEL PUMP I CAN GET TO FIT THE 308
  • GrimGreaser
    edited June 2012
    Airtex Fuel Pumps
    -6737 - inlet towards front
    -60167 - inlet towards rear
    Same spacer as original pump.
  • THANKS GRIM, CALLED AUTO PARTS AND THEY CAN HAVE IT TOMORROW A.M,
  • 51HudMan - When mounting a 6737 fuel pump on a 308 be sure the spacer gasket stack is at least .450" thick. I think this a little thicker than the spacer for the Hudson fuel pump. If the spacer is not thick enough the AMC pump will be damaged. I had a letter on this in the Sept/Oct 2010 WTN . Norm
  • The AMC pump takes a 3/16 gasket, .450" thick can give you trouble going up a steep hill. Walt.
