308 with O/D trans in 47 PU
Lee ODell
Lee ODell Senior Contributor
edited August 2012 in HUDSON
A 308 twin H engine, 3sp 2 lever O/D transmission in a 47 PU. Looking for advice to connect 47 shifter to 2 lever o/d transmission. Any help will be appreciated. Also, is there any problem connecting up the clutch linkage?
Lee O'Dell
  • Finding a steering column from a 2-lever car should give you all the parts you need for shift linckage. Not sure if the shaft would need to be shortened.
    Roger
  • lostmind
    lostmind Expert Adviser
    If you use the step down column (SIC?),you will have to modify the linkage. I had to weld in some pieces to get it to work.I used some 1/8 " rod to make a pattern.
