getting rear springs to take grease
Try poking a stiff wire in where the grease fitting goes (remove fitting first)
Roger0 -
Jack up car then put stands uder frame and let springs hang down (unload). If that dont work try replacing the Zerk Fitting0 -
Use lots of grease! I had the stuff dripping all over me until I won. Probably have some old dry stuff in there that has to be forced out.0
What Olracer said, also a good size hammer applied to the "eye" area while pumping.0
Back off the grease zirt. May be bottoming out on the shackle0
I have had luck where a joint was full of solidified old grease by removing the zerk and threading a hose into the hole and onto the grease gun. otherwise the pressure blows the quick connect off the fitting when.0
I think it says somewhere that there should be about 1/2" between the zerk and the head of the shackle, both to protect the head of the bushing, and to allow for free movement of the shackle.0
There is a tool for doing just that"clearing a zerk". it looks like a punch but fits over the zerk and you strike it with a hammmer. An internal piston exerts a lot of instant pressure that usually clears it out. Don't know where you would find one, but maybe a google search would turn one up. I have no clue where mine is or i would loan it to you.0
Back off the shackle bushing 1 turn. you are bottomed and the zerk is against the shackle. Walt.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
