head lights for 39 six
Are you looking for just the lens, or the whole bucket assembly? The lens show up on ebay from tine to time.0
Did an eBay search and found a lens for $60 and a trim ring for $35. Every now and then they show up as mentioned above.
Gary0 -
VAL
I FIXED UP MY HEADLIGHT BUCKETS FOR MY 39 ROADSTER PROJECT WITH A BALLOON AND SOME EPOXY I INSTALLED THE BALLOON IN THE BUCKET WHILE ON THE BENCH I JUST COATED THE BALLOON AFTER I CLEANED UP ALL THE OLD RUST FROM THE BUCKET YOU CAN NOT TELL THEM FROM A NOS BUCKET UNLESS YOU USE A MAGNET I COULD HAVE GROUND THEM SO THEY WERE SMOOTH BUT I SAW NO NEED TO DO THAT AS THESE WILL NEVER BE SEEN AFTER THEY ARE INSTALLED
HUDSONLY
PAULARGETYPE0 -
DON'T KNOW WHAT YEAR HEADLIGHT THIS IS, BUT I HAVE ONE OF FOLLOWING IN PICTURE.
RAY0 -
I guess I need the light assembly itself. My head lamps are the super beetle conversion type and I have one original ring and lense and in the process of purchasing another ring. But the light assembly would be what I need. Not sure how they were made back then.0
THE 1ST PHOTO IS THE OUTER TRIM RINGS WITH THE REFLECTERS 2ND IS THE OUTER RING WITH THE HEADLIGHT LENSE THE REFLECTERS GO INSIDE OF THE BUCKETS AFTER THEY ARE INSTALLED IN THE FENDER I HOPE THIS HELPS0
Nice looking parts Paul. How is the Roadster project comming? About time for a series of photos.....
YES BROWNIE YOU SHOULD KNOW HOW THESE PHOTOS LOOK IT'S ALL YOUR WORK I CAN NOT SAY THANK YOU TO MANY TIMES FOR ALL OF YOUR GREAT WORK
THE ROADSTER IS COMING ALONG I JUST FORGET TO TAKE THE OLD KODAK DOWN STAIRS WHEN I'M WORKING I WILL DO THAT TO DAY WILL HAVE SOME PHOTOS UP IN A FEW DAYS THANKS FOR THE REMINDER
Thanks Paul, its the refectors that I am looking for. Can anyone point me in the right direction0
Have you tried Donald Axelrod? 35 Timson St, Lynn, MA 01902, PH: 781-598-0523; hdlthqtrs@aol.com . He'll probably want to sell you the complete assembly (bucket, reflector, glass, trim) but you could always ask.0
I have not, but thanks Jon I will give him a try and see what comes up.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
