Looking for a twin-H linkage set up
Niels, if in you rsearch you find linkage for a short-wheelbase car (Wasp in my case) I have Hornet linkage installed right now and would consider a swap (assuming you are not outfitting a SWB car). Mike0
Hello,
I am looking for a Twin-H bellcrank for a standard trans 52 Hornet, oem # BZ 307131. Please let me know if someone has one available, direct e-mail is the best way to contact me.
I do have a bellcrank for an automatic that we won't be using if that may be of help to someone. I'll part with or trade that once I've secured one for a standard trans.
I will assume we all know the difference is on the auto trans there is an extra little arm for the kickdown. Please, no advice of just cutting off the extra tab, etc. We really would prefer the right one.
Thanks and Happy New Year!
Kelley Purdum
SLC, UT0 -
Hey guys there is a bell crank on ebay.
http://cgi.ebay.com/ebaymotors/Hudson-stepdown-throttle-bellcrank_W0QQitemZ4601829757QQcategoryZ34202QQrdZ1QQcmdZViewItem0 -
I have a complete front subframe, the factory one(except for brake drums) for sale taken off a stepdown in 1969 and stored since,in the bay area of California,please pass the word,thanks0
super 6 wrote:I have a complete front subframe, the factory one(except for brake drums) for sale taken off a stepdown in 1969 and stored since,in the bay area of California,please pass the word,thanks
You're in the Bay Area? Me too. Sunnyvale here.
I have most of a Twin H setup that I want to install, but am not femiliar with the linkage. I have one piece of linkage, which appears to attach along the top of the 308 (via 4 head bolts) on the opposite side of the engine from the carbs. It looks as though it is meant to pull on the throttles via cables, but I'm not sure how this thing attaches to the gas pedal.
Anyway, I'd be very interested in taking a look at what you have.
Thanks;
-Chris0 -
Chris...usgrant7 wrote:You're in the Bay Area? Me too. Sunnyvale here.
Thanks;
-Chris
I have a Hudson website that has links to some if not all the information you are looking for... check these links..
TWIN H linkage diagram: http://members.aol.com/stepdown53/images/TwinHlinkage.jpeg
How to adjust a Twin H set up: http://members.aol.com/stepdown53/TWINHADJUSTMENT10001.htm
Linkage installed on a Hudson engine:
http://members.aol.com/sanjuana/Images/308wTwinH
Good Luck
Ken0 -
Heart Of Texas wrote:Chris...
Good Luck
Ken
Oh perfect! The only thing I'm missing is the link between the "bell crank?" and the piece that mounts to the top of the engine.
My setup (piece that mounts to the top of the engine) seems to have a 4th "arm" which I suspect has something to do with automatic transmissions. I've got a manual, so if anyone needs mine and can trade I'm up for a swap.
I suspect I can just use cable to go between the top piece and the carbs.
-Chris0 -
Hello Im in San Jose and have a complete Twin H set up you can look at if you need to.Phill 408 690-69890
[email]cfennen@......com[/email] put satx.rr in dots. Has a balanced set of carbs and linkage for a twin H, I think he wants less than 150 dollars for the set.0
1952 Hudson Hornet wrote:Hello Im in San Jose and have a complete Twin H set up you can look at if you need to.Phill 408 690-6989
Thanks Phill! I'll give you a call in the next couple of weeks and take you up on that.
-Chris0
- 120 Hudson 1916 - 1929
- 612 Vehicles
