Door Sill Plates Installation
When I placed mine (coupe), I placed a piece of rubber foam at both ends. The rubber should be a tight foam black piece that squishs down a bit to stop water from entering the footwell.0
They were originaly sealed at the ends with that body gum simmilar to modeling clay .If you can find it ,of course anything that will keep the water out is the main thing as mentioned abouve,
Roger0 -
Walk into most parts stores or any body shop supply and ask for "strip caulk". Buy the 3M brand if they carry it. It comes in gray or black and in this step plate application, gray was used as I recall.
Yes , same stuff . never seems to set up completely , stays in place to seal odd shaped gaps,
Roger0 -
Reminds me of plumbers putty, not that I would ever use it on my car. :-$0
Strip caulk is a very good product, used a good bit of it repairing my customers cars especially around the heater box when replacing heater cores. Have also used it in a couple of spots on my Pacemaker. My car had some formed rubber seals at the ends of the door sills. I ended up buying a garage door bottom weather seal ( at Home depot), cutting it to the length of the old one and gluing it in place with contact cement as was the old one. The new seal has a slight bend/crease in it that fit near perfect. Guess I should have taken photos as I did it.
Jim Spencer
WNY/Ontario Chapter0 -
I seam sealer-flowable when I can get it.Lord Chemical makes a good one called "fusor" the rep comes by the school each year and does a demo and it does work.I used it to bond a replacement rocker panel on one side of a brand X and welded the other side -15 min vs two days and no warping -amazing products0
That would be good for sealing gaps and seams but I dont think he should put it under his Threashold plates. They need to come up on occaision ,
Roger0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
