LATE STEPDOWN REAR AXLE SEALS AVAILABLE ?
Although I have the numbers that were current in the 70's and 80's, my local parts store cannot cross reference them to currently available seals. I need numbers for both the inner and outer seals used in the late 52 to 54 Spicer rear axle. I hope that there is something out there being produced that is useable.
Thank you, Bruce
Thank you, Bruce
Don't have the sizes handy but they are an off the shelf seal, nothing special.0
Bob, I am sure that you are correct. All I need is the part numbers!
Thanks, Bruce0 -
Have you got a sample you can take to the parts store, they should be able to measure and supply from samples.0
Just contact Norm Blackmer in the CIC chapter and he can supply you with all brake parts and seals. (9090-984-5544 Keep the business in the Hudson clubs. Walt.0
brumac - The outer seal - CR 17310 or TCM 17243 TB ( same as Hudson axles) The inner seal - TCM 132282 VB. Norm0
Herm, thank you. Bruce0
- 184 The Flathead Forum
