LATE STEPDOWN REAR AXLE SEALS AVAILABLE ?
brumac
edited April 2013 in HUDSON
Although I have the numbers that were current in the 70's and 80's, my local parts store cannot cross reference them to currently available seals. I need numbers for both the inner and outer seals used in the late 52 to 54 Spicer rear axle. I hope that there is something out there being produced that is useable.
Thank you, Bruce
  • Don't have the sizes handy but they are an off the shelf seal, nothing special.
  • Bob, I am sure that you are correct. All I need is the part numbers!
    Thanks, Bruce
  • Have you got a sample you can take to the parts store, they should be able to measure and supply from samples.
  • Just contact Norm Blackmer in the CIC chapter and he can supply you with all brake parts and seals. (9090-984-5544 Keep the business in the Hudson clubs. Walt.
  • brumac - The outer seal - CR 17310 or TCM 17243 TB ( same as Hudson axles) The inner seal - TCM 132282 VB. Norm
  • Herm, thank you. Bruce
