Rear end needed for 52 to 54 Hornet Hydramactic Type "P" In Minnesota
HornetSpecial
Hello Hudson folks!! Needing a little help from our Hudson community. Looking for a rear end to go in 52 hudson Hornet. It is the later rear end Type "P" it is identified by a housing with a bolted cover. It needs to be out of a car with a hydramactic tranny. It is the rear end they used from 52 to 54. I will drive if close enough. I live in Lindstrom MN 55045. Contact info 651-9191 or cell 651-492-9285 Thanks for any help!!
Best Regards, Paul
Best Regards, Paul
That is a DANA 44 rear you are looking for with the 3:08 gear ratio for hydra-matic transmission. There are plenty around. My friend just bought 2 complete units to install in his 2 overdrive Hudson Hornet cars. A job for me if I get back on my feet. Best all around, stay in third gear till 45-50 MPH, then overdrive. You will be buying a lot less gas. That rear started in the second series 1952. Walt.0
Walt is right about 45-50MPH before overdrive. I did this in 1963 to my 52 Hornet. Drove it to Hamilton, Ohio. Clutch started to slip at low speeds. eventually had to replace clutch plate. I also lost top speed. I was out run by a 56 Ford. Put the original rear end back in and out run the Ford at a later time. There may have been other factors involved but, I think the 3.08 ratio is to high for a car with overdrive. Just my opinion.0
disregard0
Not to hijack the thread, but If someone has one of these rear ends in Florida.. I might be interested.0
Hey Dave, if you need one and can't find one locally let me know
Has anyone put the older version in this year car? and what were the complications? I had done it many years ago and had to change the drive shaft. But using the entire diff/axel, springs and all, I think we had few problems. Can't remember back that far, but I know we did it, cuz we raced them alot and saved the dana for the drags and destruction derby. [ SORRY ABOUT THOSE], We used up Borgs for the fig 8's and circle. They would not stand up to dragging or derbys, neither did the smaller clutches. But cork was fine, if it was a 2 lever set up and full of fluid and ya did not ride it. Just wondering if anyone is as old as me and remembers what else was needed.
Bobby0
