carb flooding
Sounds like you have the wrong float setting. Did you use a NOS kit, if yes the needle seat will not work with todays gas. List car year and the number that is on the brass tag, and I will try to help. Walt.0
Hi Walt,
Sent you a PM about carb rebuild. Did you get it?
Tim in WI0 -
TIM I HAVE THE KIT IN STOCK FOR YOUR CARB IT IS $55 + $3 SHIPPING IT'S A NEW KIT WITH A NEW STYLE FLOAT VALVE THAT WORKS GREAT WITH THE NEW GAS0
Hi Paul,
Thanks for the info. Does the kit come with the accelerating pump? I'm sure my carbs need that as well. We have a '54 Hornet with Twin-H and the WA-1-968s carbs.
I was trying to reach Walt because I know he rebuilds these carbs and I wanted to know what he charges for that service. I'm undecided if I want to rebuild them myself. Thanks again.
Tim in WI.0
- 112 Hudson 1916 - 1929
