Brake light switch
Hoosiercrosley - A Jet info sheet by T.L. Ray & David Sollon shows a Wells #F4805. I have a Jet manual that shows a switch that looks like the same as a stepdown - Caquest # 53-5449I. Norm0
I'VE FOUND THAT IF YOUR RUNNING DOT 5 BRAKE FULID THE OLD STYLE SWITCHS DON'T LAST LONG (ABOUT A YEAR) THE FULID MAKES THEM SLOWER THEY WILL NOT TURN ON THE BRAKE LIGHT TILL THE HAVE REACHED 20 PSI I HAVE BEEN USING THE ONES USED BY HARLEY DAVDISON IT'S A LOWER PREASURE WORKING SWITCH ( ABOUT 3 PSI) I'VE HAD ONE ON MY PACEMAKER CV FOR 5 YEARS NOW WITH NO PROBLEMS0
Barry, I put a new stoplight switch on my '54 Jet last winter. Seems to be working just fine (so far). I used Duralast from Autozone #F4805. Ran about $6, and was an easy install.
Joe0 -
I bought two of those HD switches from PAULLARGETYPE years ago: works like a charm.0
Thanks guys, mine is doing what paulargetype was doing, I have to stand on the brakes to get the light to come on. Don't want to get hit in the butt, these Jet body parts are hard to find!
Barry Smedley
53 Super Jet
and a bunch of Crosley's0
