fan blades
bartibog1
edited July 2013 in HUDSON
has any one every changed the 4 blade fans on 1953 super wasps to either a 5 0r 6 blade type with any results like running cooler etc. if so any part numbers
steve
  • Yes ,changing to a modern flex fan will aid in cooling. All other things being equal 20 degrees more cooling was gained when a friend put one on a 1949 Super with 262.
    Get the right spacer for good right clearance,
    Roger
  • Any advice on the type or model number of the flex fan and the spacer needed.
  • rambos_ride
    edited July 2013
    The fan should be min of 3/4 of an inch from the radiator - I think anything over 1.5" and you'll start losing efficiency.
  • We used a Imperial Flex Fan by Hayden # 221618 . I dont remember the size spacer off hand .I want to say 1" comes to mind but as stated above its whatever gives you proper clearance,
    Roger
  • Stay away from those plastic fans. Walt.
  • I would not think a plastic fan is a good idea either . That Imperial one has Steel frame and flexible Stainless blades with good pitch to it. The centrifugal force straightens them as speed picks up . Provides similar effect to a clutch fan.
    Roger
  • Speaking of fans, it is a very good idea to thoroughly check the blades, pulley and bolts regularly. I have seen the aftermath of a wayward fan blade through a hood/bonnet. Scary.
  • Be carefull if you buy a stainless steel flex fan. The blades are dangerously sharp and will slice you quicker than a ginzu knife.
