clutch fluid for 1930
4Hud
edited July 2013 in HUDSON
How much clutch fluid does a 1930 Hudson 8 require? I have an instruction booklet for the 1930 Essex, it says 8 ounces. Thanks. Bob
  • OK. I found in the 1930-33 Hudson service operations manual it takes 1/4 pint of fluid or 4 ounces.
  • YES 29 AND 30 TOOK 1/4 OF A PINT THERE ARE A FEW 1/4 PINT 4 OZ CANS AROUND I HAVE 1 IN MY CLUTCH CAN COLLECTION IT LOOKS JUST LIKE A REGULAR 1/3 PINT CAN BUT IS LARGER AROUND
  • Thanks for the confirmation Paul. I took the 8 ounces out and put 4 ounces back in, now I can get it into gear.
  • I read in an early Hudson manual that use of Kerosene was recommended for clutch ?
    I think this was early '20's ?
  • THAT WAS BEFORE THEY STARTED MAKING THERE SPECAL MIX IT HAS KEROSENE NEEDS FOOT OIL AND SOME OTHER STUFF I WOULD USE CLUTCH FULID OR ATF DEXTRON
