Temperature sensor needed ( HH 52)
Michel,
If it's not working at all maybe he used too much thread sealant and the sensor is not grounded. Looks like he has quite a bit on there.
John0 -
So, does it means he has the right device but that it was not installed the proper way? I will transfer your answer. Thanks John, Michel0
Michel,
Have him hold a small piece of wire on the brass sending unit housing and a head bolt, see if the temperature gauge shows a reading with the engine warm. If it does then the sending unit is not properly grounded.
John0 -
Thanks for this trick! Michel0
- 112 Hudson 1916 - 1929
