Adjusting 308 Hornet valves
I had a friend come over to listen to my Hornet engine and we noticed a puff of air comming out of the front twin h carb and the longer it run the more it backfired out the exhaust pipe. Will it be hard to remove the passenger side inner fender panel to adjust the valves . Walt I need your help. Hudsonly Ray
The inner planel comes out pretty easy. Adjust your valves cold at intake .014 and exhaust .017, using new feeler gauges. Sure hope you do not have a burnt intake valve. Pull a compression test, should be at least 80 in all cylinders. Walt.0
Thanks Walt I only run the engine a few times for a short time. I hope every thing is alright.
Ray0 -
Should be able to see a bounce on a vacuum gauge too. Might want to try and narrow it down by pulling plug wires one at a time while its running and see if you lose some of the gauge flutter. Either way your still going to have to check the valve lash.0
Thanks for everyones help. I heard from our friend tonight that this Friday a trailer is coming to take the car to our friends place to be finished. I hope ivery thing turns out well. Ray0
This afternoon the trailer came to our place and took the Hornet away I was kind of sad to see it go but now it will get finished. Thanks to all for the help. Very Hudsonly Ray0
