308 head and 262 head
drivergo2
edited August 2013 in HUDSON
Will a 262 head gasket fit on a 308 block and head, and will a 308 head gasket fit on a 262 block and head ? thanks John
  • The brief answer is "No". The heads are interchangeable from '51 onwards, but if you tried to use a 262 gasket on a 308 it would overlap into the combustion chamber area. Lots of people use the 262 or even 232 heads on a 308 to get higher compression, but you must use a 308 gasket. Not sure about a 308 gasket on a 262 block, but this would lower the compression slightly as there would be areas not covered by the gasket.
  • Geoff is correct,.To expand on Geoff's comment. Notice he said "'51onwards". 48-50 262's had a narrower block and head, so will not interchange.
  • I will add that I have seen a wide block head on a narrow block. it hung over the drivers side of the block. It was running. I'm not sure , but I think it was a car from Jack Millers collection.
    I was always curious about this. The car was sold and I forgot about it.
  • lostmind-
    Not sure, but that could NOT have been ideal.
  • Thanks you guys , Thats got it covered. John
  • The car will run, but I'm sure you wouldn't want to head across country in it.....
