52 HH DRIVE SHAFT BEARING
Check with Jason at Vintage coach on the bearing 909-823-9168 Tues. thru Sat. 8am till 5pm. As far as trans fluid, use Mercron/Dexron III.0
DEXTRON 2 FOR THE FULID AND 1972 CHEVY TRUCK ON THE DRIVE SHAFT CARRER BEARING0
thanks for the quick response guys.0
Jeff, there are two sizes of driveshaft bearing. I would be happy to supply you with either one but I have to know the diameter of which one you need.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
