My '40 is chirping
Looked again. Sounds almost like a bearing. What is on the right side of the motor below the carb that might make the sound?0
Heat riser?0
Blown exhaust manifold gasket? Clearance takes up a bit when hot.0
My T8 was making a strange and really faint high pitched noise that rose with rpm. It sounded like a miniature blower whine from a mile away. What it was was the carb mixture screw was too far in, and as soon as I wound it out a little the noise disappeared.0
Thanks guys,
Checked the heat riser and it is still stuck in place. Just replaced the exhaust manifold gasket. Don't see any sign of a leak. Tightened the bolts when hot and could get them to move.
For these and the carb mixture screw I have ordered a stethoscope. The sound is intermittent so will have to wait for the stethoscope and the chirp to show its head.
The more I get to know this car the more I like it.0 -
Noise Location can be very deceiving and difficult to pin point their location. I suggest you grease the water pump before tearing into this further. The pump ofter chirps when grease is needed. The Ford club has reproduced water pump grease.
Allan0 -
Could this be the bearing in the distributor ? They require oil regularly , never heard one squeak but have seen worn out ones.
Roger0 -
Soon after all this advice the chirp went away. Have not been able to use the stethoscope.
Just in case I greased the water pump, turned the distributor grease cup, adjusted the carb, torqued the exhaust manifold gasket and lubed the heat riser. Fingers crossed.
Thanks guys0
- 103 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
