vacuum pump
essexcoupe3131
edited September 2013 in HUDSON
HI All,
looking for a all in 1 vacuum pump and alternator to boost my braking vacuum
as the cam is just too lumpy
any info would be great, a nice polished unit would be great if possible, will go into my coupe
thanks
Mike
  • ESSX28-1
    Hi Mike
    You still 6 volts?
    If you are then I have a 6 volt Vac pump I got x eBay some years ago to try to sort my vac powered windscreen wiper. I've not used it all these years & prob never will, so it's yours if you want it. If I recollect correctly, it previously powered a GM Convertable Hood mechanism.
    Dave Y
  • Hi David,
    no run 12 volt system, i do have a Volvo 1 that I have been mucking around with
    and I know that Toyota has a diesel alternator that has a built in pump as part of it
    was hoping to find something with a bit of bling to go with the rest of the setup
    thanks for the offer
    what year does the pump come off as I will keep my ears open in case someone is looking for 1
    Mike
  • Some of the 82 Chevy Citations with v-6 had a vacuum booster under the battery. I would think other GM of similar configuration may have them too. Would be 12 volts of course,
    Roger
  • hella makes an electric vacuum pump $150 from Summit: summitracing.com/parts/hla-009428087
  • Will check it out
    thanks Doc
  • Why not add a vacuum tank like they used on the 50;s cars with power brakes? A hose with a check valve in it goes from the intake manifold to the tank and another hose from the tank that hooks to the vacuum fitting on the booster unit.
  • Thanks Marconi, will throw that into the mix
    and see where I go
    Mike
