54 hornet not charging
Most likely the brushes worn out. The dash light gets it's ground through the armature, so if the brush is not making contact the light will not come on with the ignition. Check that for starters.0
Ty will do0
The 1954's had a 45 amp generator and a special voltage regulator. They must be matched. Walt.0
