looking for 2 KEEPERS w/tab-ears to secure crankshaft bolt (1.5" dia); wide block 308
If your asking about the lock Tab on the Damper Bolt they are usually destroyed after a couple rebuilds so I just use Red Loctite then torque to the Max on my Wrench (120#), then tighten a little more with a Bar since its a 3/4" bolt.0
Do you mean the locking washers that go on the main bolts?? Walt.0
Damper bolt0
- 175 The Flathead Forum
- 602 Vehicles
