How do I find 308 repair manual
1ST OFF DON'T USE THE ORIGNAL BOLTS IN THE 50'S THEY DID NOT HAVE GRADE 8 BOLTS SO SPEND THE MONEY AND BUY NEW GRADE 8 BOLTS
AND I ALWAYS USE THICK WASHERS
I'M SURE ALEX BURR HAS A MANUAL ON LINE OHHH ALEX PLEASE HELP THIS MAN !!!
THE PARTS BOOK I HAVE SAYS 70 TO 75 FOOT POUNDS I ALWAYS START IN THE CENTER AND WORK MY OUT TOWARDS THE ENDS BOUNCING BACK AND FORTH TILL I'M DONE THAT IS COLD AND THEN AFTER RUNNING IT TO GET IT WARM I DO IT AGAIN THEN AGAIN AFTER SOME MORE RUNNING ALL TOLD I MAY DO IT 6 TIMES
Wow, thanks for the information! I will take your advice and purchase the grade 8 bolts. I appreciate the help0
Also, it's almost essential to tap-chase the threaded head bolt holes with a well-oiled tap, plus vaccuum out debris or back wash out all the debris/oil w/parts cleaner of some sort (brake parts cleaner might work well). This serves to remove rust and Permatex/sealer residules. Careful not to let debris run/fall into the cylinders.
NOTE: an idea is to keep a running vaccuum hose w/crevice tool located closely to the tap during the tapping process.0 -
Thanks. I will make sure I chase the threads with a fresh tap. This is a great site with a wealth of knowledge. I'm pleased to have found it and hope I can return the favors down the road,0
1948-1952 shop manual recommends 60-65 foot pounds for six cylinder engines. You can find a copy of this manual in the online library @ http://hetclub.org/burr/lithomepage.htm - look under 1948-1954 Manuals. The info is on page 3-40 Engine, right column.
When torquing the head torque it down to spec, then warm the engine to operating temp and re-torque. Do this at least twice - I'm sure somebody will recommend a couple more times.
Alex Bur
Memphis, TN0 -
Check the size of the bolts first. Later (55-6) 308's used 1/2" as opposed to the earlier 7/16".
The 7X race motors also used 1/2" and more than a few engines have been converted to 1/2" bolts or studs along the way.
If you came across this website while looking for information about a Hudson, Essex or Terraplane automobile, you are in luck. These posts provide a wealth of information on all subjects pertaining to the care, maintenance, rebuilding, etc. of your Hudson Essex or Terraplane automobile. I encourage you to not only post questions that you need help with, but also offer information that will be helpful to others.
There is an international club that is dedicated to driving and preserving these great automobiles; The Hudson Essex Terraplane Club, with over 3,000 members worldwide. There are also small regional chapters across the United States that provide a sense of camaraderie in our passion of these fine automobiles. Becoming a member is easy, and you will receive the award winning bi-monthly publication, The White Triangle News, with your membership.
If you are interested in joining the Hudson Essex Terraplane Club you can go to the following links and sign up by using PayPal, or print out an application form and mail it in along with a check. If you wish to receive a free copy of The White Triangle News and see what a valuable resource it is, you can drop me an email with your name and mailing address and I will send you a copy.
We are glad that you have an interest in a Hudson, Essex or Terraplane; we consider them to be the finest automobiles ever built. We would love to have you as a member, please join us.
Sincerely,
John Forkner
New Membership Coordinator
Hudson Essex Terraplane Club Inc. (Our club website)
http://www.hetclub.org/
HET Membership (Online membership application)
http://www.hetclub.org/index.php?option=com_content&view=article&id=81&catid=78&Itemid=633
Membership Application ( Print and mail application)
http://www.hetclub.org/het_app.pdf
HETForkner@aol.com (email me to receive a copy of the White Triangle News)
(Drop the HET in the email address, but please put HET Membership in the subject line to keep it from going into the spam file, and remember to provide me with your mailing address. Any emails received with an attached file will be deleted due to virus concerns.)0 -
Thanks again for all the info and for a link to manuals. It's great to find such a helpful group.0
- 112 Hudson 1916 - 1929
