Headlight Conversion
dustymaxhudson
Where can I get a conversion kit to convert the 6V headlamp bulbs to 12V? I need to convert both headlamp and blinker.
In most cases the 6-volt lamps have 12-volt twins. If you have the lamp numbers I'm sure someone will cross referance them for you.0
Most Headlights today in Auto Stores are 12 Volt. Just take in your 6V bulbs and match them. Same goes for all your other 6V bulbs...I think the headlights are #6012. Suggest installing Halogen headlight Bulbs...
Ive found wiring headlights through a Universal 30 Amp Relay provides even 'brighter' lights for older cars. For EZ Instruction... Google how wire headlight Relay0
