Who sells a freeze plug set for a Hornet?
ivanz62
edited June 2014 in Parts & Pieces
Is there anyone who puts together a kit of what you need or do you have to source them individually?
  • I had a freeze plug rust out in my'96 Olds - garage installed a universal type that is tightened in place with a wrench. If that's any help.
    Alex Burr
    Memphis, TN
  • Dale Cooper does not have a set--he's thought about it but not done it!
  • Ivan, mail me your needs. We have all of them in stock,including the rear cam plug. Thanks Doug .
  • I went to Napa with the old one, and they matched me up a set.
  • I got some from Dorman for my 254 head. They list many sizes.
  • Can someone list the sizes (maybe part numbers from purchasing experience) for the various plugs used on the 232, 262, 254 and 308 engine?
  • Ol racer
    edited February 2014
    Hope this helps out...
    A few Yrs ago I spotted Soft Plug Kits in the White Triangle then bought a few Sets. The Set came with a full page of helpful proper Installation Tips which I kept. I went into my Shop to retrieve the Page but there's no name or contact info on the Page..... Too bad because it was a nice deal and It saved the hassel of finding all the sizes..l Dont know if that person still advertises or not.... If not, perhaps someone could put together another Kit and Market it if I provide the sizes...
    (3) Shallow 2" Brass Cups LS Block
    (1) 1 13/16 Convex Steel Disc Cam Rear
    (1) 1" Convex Steel Disc Upper Rear Block
    (2) 11/16" Convex Disc Steel Frnt & Rear Oil Galley (Suggest Tap for Pipe Plugs)
    (2) .567 Shallow Cup Steel RF & LR Block Skirt
    (4) 3/8"Deep Cup Steel RS Block
  • Thanks Ken!
  • Dale Cooper has the entire set of freeze plugs including the cam plugs for $25 dollars for the set.  That's sort of hard to beat.
  • For those who are interested - download a copy of the CLEVITE catalog listing the freeze plugs and interchanges....
    http://www.mahle-aftermarket.com/C125790900540AC0/vwContentByUNID/140E9908DC38DBBBC12579AA005057D9/$FILE/EP-30JD-06web.pdf
