Type A Transmission Fluid?
[Deleted User]
edited February 2014 in HUDSON
What are other owners using for automatic transmission fluid? I found a service manual that states Type A fluid.
Any help is appreciated?
Oh, it's a '54 Hudson Jet.
Thanks!
M-
  • Use Dexron III or equivalent fluid in Hydramatics. If it hasn't been run in a while, drop the pan and check for gunk and clean the filter.
  • Will do. There seems to be a nice leak.  I have a puddle of trans fluid under the car. I hope it's just the pan gasket. I've ordered a new gasket.  Would it be anything else? Is there another area that's prone to leak trans fluid?
  • Front and rear seals. Mine had a nasty leak from the front. Requires dropping the Trans. Little different than if you've ever done another automatic. There's a hydromatic manual on the HET Club website. I'll find the link shortly...
