In need of bullet connectors
Aaron D. IL
Hey guys on the new forum. I'm in need of some bullet/Snap/banana connectors for the wiring harness on the 1950 P sedan so I can finish it. Mostly I need some to connect to the OEM dashboard switches and such. I probably need some to fit 12-16 Guage wire. I don't know the exact sizes or metric equivalents. If you know please respond. Also please respond if you know of a good source for these wiring connectors. I'd rather have some similar to original. Not those cheap plastic crimp-on ones. I plan on soldering them. Or if you know of an assortment pack of sizes I can get that would work too. Looking on the internet has been surprisingly difficult to find these connectors.
Thanks in advance for any leads you can give.
1
Make sure to solder them on, just like the originals.YnZ has almost everything you will need.0
The bullet connectors you need are also available from Dell City Electrical Supply.
NYLON-INSULATED Item Description Price 1+
1000+
10000+ Qty in
PackageIn Stock Add to Cart 641205 Male Bullet Terminal, .156", 22-18 Ga (100 MIN) 0.22620
0.18400
0.14610 100 PC ✓
642205 Male Bullet Terminal, .156", 16-14 Ga (100 MIN) 0.15590
0.12690
0.10070 100 EA ✓
642405 Male Bullet Terminal, .180", 16-14 Ga (100 MIN) 0.22670
0.19260
0.15250 100 PC ✓
Get the desired quantity from ynz or Rhode Island Wiring, and be sure to get the .156" size..0
Here is an example of what ether Rhode Island Wire or YNZ has to offer. Also an example of what they look like soldered on the wire.1
I plan on soldering them on like original. The modern crimp-on kind you can get at the store are cheap and don't hold as good a connection. 16 GA size is not hard to come by but the fatter 12 GA type connectors are. Thanks guys for the response.
