Fan Blade Length
48Sed
edited March 2014 in HUDSON
I have read conflicting articles on the proper length of fan blade used on the 48 Commodore 8 cylinder.
I measured mine and it is 17" tip to tip.
Did Hudson start putting on 18" during the production run?
Thanks
  • 48Sed
    edited March 2014
    Was this 18" blade ever used on a Hudson 8cyl engine?
    The tips are bent forward maybe to pull more air in?
  • The fan blades pictured are the type used in 1952-1954 (or more).  #305153.
    the 1948-1951 fan blade was also 18" but without the "tweaked" tips.  # 302398
    the 46-47 fan was a 2 piece blade that was 17" .  #166280
    the 34-42 fan was also a 2 piece blade 17"  #45925
    The 52-54 was also wider and supposedly quieter  due to the Tweaked tips.
    Many stepdowns have been fitted with the later fan, for better cooling and quieter operation.
    "Ric"
  • Ric
    My car is the Commodore 8 and there is little room for a 18" fan.
    Do you mean the 18" #302398 was for the 262 engine?
  • 18" was for both, Maybe radiator needs repositioning to give clearance. In 48-51 was the fan without the tweaked tips. straight blades required less space.
