inline tibe stainless brake lines
pseftoncomcastnet
Has anyone used Inline Tube's stainless steel brake lines for a stepdown. I am assuming that a 1951 Hornet has the same lines as a Commodore. Also, does anyone have a recommended source for new flexible brake hoses?
Peter S.
Peter S.
I prefer to roll my own with cunifer. http://www.fedhillusa.com/
The hoses aren't uncommon and should be available just about anywhere.
I used to make all my brake lines with stainless. I switched to cunifer and won't go back! Much easier to use and will outlast the car.
Now if you are building a custom-street rod and the lines will be seen, then stainless will give you the "bling" that cunifer won't. Stainless is very tough on the flaring tool .
Try
http://stores.ebay.com/BRAKE-HOSES-UNLIMITED/Hudson-/_i.html?_fsub=11277937&_sid=61203586&_trksid=p4634.c0.m322
Made in the USA.
When I used Inline Tube to do the lines on my '49, I had to have them add the flares. So it was a little extra shipping to send the (straight lines cut to length with fittings added) back to them for that step, but they came out great, and I don't think they even charged me for adding the flares.
I make all my lines myself in SS. Finally bought a flaring tool to make great factory flares. Using my old flaring tool was iffy at best, sometimes it they would leak, sometimes not. I buy my stainless locally in straight 10 ft. lengths and bend them by hand.0
I use a hydralic powered flaring tool, about the best you can buy. I have to replace the dies on a regular bases when doing stainless lines.
The cunifer tubing is so much easier to work with.0 -
I've never done double flares in stainless. All the stainless(even brake lines) I've done were single flared 37* for AN fittings. One of the better tips I've picked up along the way was using a zip wheel to cut the tubing then hand file/debur. The typical tubing cutters (especially with less than fresh cutting wheels) work hardens the tubing right at the point your going to flare leading to cracks.
That's how I do mine, use a zip wheel and file by hand. then double flare.
Pardon my ignorance, can you enlighten me as to what "cunifer" is, and also describe a "Zip Wheel"0
Here you go-
http://brakeconnect.blogspot.com/2012/11/4-reasons-to-use-cunifer-copper-nickel.html
http://store.fedhillusa.com/316475mmtubingandnuts.aspx
A "Zip Wheel" is a term used for a thin cut off wheel. I use 1/32" to make the cuts on tubing. It comes in sizes for die grinders up to hand held grinders.
http://www.ebay.com/sch/Cut-Off-Wheels-/58196/i.html
I have found brake lines at Advance discount Auto that are cunifer. Not always the proper length though. Very easy to bend and resistant to rusting.
Thank you for the explanation.0
- 104 Essex Super 6
