That little cloth cowl strip
pseftoncomcastnet
My efforts to research this have been hampered by not knowing what to call it...
Does anyone know a source for that woven strip that runs across a stepdown's cowl? It is fastened to the cowl with a line of tacs and essentially seals the gap with the rear edge of the hood.
Peter Sefton
Peter Sefton
"Cowl lace" or "cowl lacing" Several types made. Get the right width and profile from any of many hobby suppliers.
Restoration Supply in Escondido Ca sells it.0
I believe Dr Doug carries all the proper widths as well.
Jeff
Model A Ford 1930-31 radiator shroud lacing is identical. usually sells for about $10.00. Keep your old nails and use again in the same holes.0
Yep, buy from Hudson folks. Dr. Doug carries them for all Hudsons.0
sent you a pm, ken0
Thanks for the tip on the cowl lacing. The hood on my 53 always tended to just touch the cowl in front of the Pside wiper and if I left the cowl vent half open, there also. I had to make the hood come forward about 1/16 inch . What a nuisance. Even now I have to be careful to open the hood by favoring the right side first. I never thought of raising the cowl lacing. I give it a try next time I need to make an adjustment0
- 104 Hudson 1916 - 1929
- 172 The Flathead Forum
- 599 Vehicles
