491 Drain threads
Can someone tell me what the thread is for the block drain on the straight 6?
Also what the thread is on the radiator drain?
the radiator petcock on the was removed and so was the block plug when the car was parked many years ago and i need to get them replaced so i can fill the cooling system.
thanks,
Rick
Both mine are 1/4npt0
thank you, i will clean them with a tap and see if i can get it sealed up.
- 182 The Flathead Forum
