Desperately seeking '51 Hudson Ring Gear
DocHornet
edited May 2014 in HUDSON
Well,
All youse guys' predictions were true regarding running a 6V starter on 12V.  Mine's been in operation just 2 years or so, and probably less than 1,000 miles, but when I pulled it out for inspection (and conversion to 12V) recently, I found the starter pinion totally chewed up, and the ring gear doesn't look great either.  Seems like I did have the ring gear repositioned 180 degrees when I installed (there were already some bad spots), but now it looks as if I'd be wise to seek out a new gear.
Any suggestions for sources of either a new, or serviceable ring gear for '51 Hudson Hornet 308 with manual overdrive tranny?
  • FYI
    Check with your local Automotive Machine shop. If a replacement isnt available, you could inquire on the Forum for another flywheel....
  • 41 through 54 all standard trans. are the same. Should be able to find good used or replacement type.
    "Ric"
  • I should have a flywheel available if you need one. Where are you located?
  • www.vapinc.com
    You'll see that they list it as for '34 to '40 but if you follow the parts number supersessions, you will find that it fits all to '54. $135 for a new one.
    Frank
  • Hey Doc,
    You might also try Dr Doug, and Al Saffrahn. Both listed in the WTN.
    Good luck,
    Jeff
  • Also, if they dont have one, a guy in Wisconsin does ring gears.
    His name is Al Suehring phone # is 715-677-3809. I came across his card a few years
    ago at the Portland Swap Meet so not sure if he is still doing em.
    Jeff
