46 rear springs
paulrhd29nz
edited June 2014 in HUDSON
I need to get my rear springs re arced.  Does any one have any specs. on this?
The books only mention scale/ weight.  They are for my pickup with 9 leafs.
Thanks in advance.
Paul
  • Part of your problem is someone during the truck's lifetime has removed about 4 leaves from each side - started life with 13 leaves.  Because the springs were such heavy duty units, they probably did not have as much arch as those of the sedans and coupes.
  • I'm guessing they were removed for a better ride. The springs are totally shot. I can bounce on the bumper and hit the frame bumpers on the axle. I need to get them re arced.  Now i am wondering about the front coils.
  • Ok. Need some help here. Turns out my rear springs are done for. They are not re-arceable.
    Is there a modern upgrade that will work? Has any of you fitted springs from another vehicle?
