40'S HUDSON TRUCK GAS TANK WANTED
PAULARGETYPE
HI I'M TRYING TO HELP OUT A FRIEND WHO HAS A REAL NICE TRUCK THAT IS IN NEED OF A GOOD GAS TANK HE PLANS ON HAVING IT DONE UP BY RENEWED SO IT COULD HAVE A LEAK BUT HE'S LOOKING FOR A GOOD TANK
My truck has a 38 ford car tank0
TOM DID IT BOLT UP FAIRLY EASY I KNOW I'M GOING TO HAVE TO MAKE SOME MODS TO IT ?0
I will get pics0
I installed an late '80'3/early 90's Camaro tank in my Truck. It was new at Swap Meet and got a deal but didnt know if would work..
Suprisingly, it fit up nicely, but had to cut off the Camaro fill pipe, then install a short pc connector hose to extend a pipe up into the fender hole....
CHUCK WHAT YEAR CAMARO ?? THANKS LOOK FORWARD TO SEE THANKS TO BOTH OF YOPU0
Paul,
The Camaro Tank was brand new setting at Pitts Parts Rama Swap Meet..The guy removed it from a new Camaro they made into a Stock Car installing a Fuel Cell. Now that I give it more thought, I believe it was around 1995 They may have had the tank in their garage for a few Yrs though.... I even utilized the Straps that came with it in my '47 Pickup.
The Fill pipe had the wrong twist so I cut it off then put a short hose to connect another pipe up to the left side...
(A connector hose is no problem since all Ford Pickups I had for many Yrs had a hose connecting 2 pcs of fill pipe up to the fender).......
THANKS CHUCK1
Tank gets even better,,, I forgot to mention that I removed the Camaro 'In Tank' Electric fuel pump in practically the same location as Hudson Sender, then installed a Universal Float from JC Whitney (at that time), However, now days I know 'someone' that sells Floats. Tank looks like it came in the Trk.....Suggest looking at used tank in Yard, rinse and modify a bit and ready to go....
i used a 95 G10 Chevy Van tank. The stock fill neck worked perfect,and fits awesome
Can a picture be posted showing the filler neck connection using one of the above tanks?0
- 105 Essex Super 6
