Hudsonite fluid
DAVE HOW DO YOU KNOW YOUR A TAD LOW? IT'S ONLY 1/3 OF A PINT THE ONLY WAY I KNOW TO MEASURE IT IS TO DRAIN IT. NEVER PUT THE STUFF YOU DRAIN OUT BACK IN. IN A PINCH I WOULD USE (AS MANY GUYS HAVE) ATU DREXTRON 3 IT WILL WORK FOR YOU DOUG WILDRICK HAS IT IN STOCK0
Have used Dexron 3 for twenty odd years, buy it off the shelf at any parts shop.0
I run a formula that was posted some years ago. I believe it is Walts formula. It is 2oz of Dextron, 2oz of 10w30 , and 2oz of Marvels. It has worked fine for me.0
I have about ten cans of original stuff on my shelf and no longer have a Hudson that uses it. Be happy to sell it just send me a note at browniepetersen"at"readytek.net0
DAVE I WOULD LIKE TO HEAR THE ANSWER TO HOW YOU KNOW IT'S LOW??0
It's leaking fluid.
Thanks to all for your advice. I have replaced the clutch seal a couple of years back, not in a big hurry to repeat, but maybe this winter.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
