Charging issues
I suspect my 52 Hornet is overcharging the battery, one of the battery filling caps popped off a while back. Any suggestions on how to best test the charge rate. I am replacing the battery after two years, don't want to replacing it in another two years.
Dave Eddie
use a voltmeter at the battery. Are you 6 or 12v ?0
6 volt0
7.2 volts at the battery , approx. 1500 rpm. Recheck with headlights and heater motor on.
A bad cell in the battery can cause gassing and blow the cap off.
At 1500 rpm with headlights and heater on I have at charge of 8.3 volts. Can the voltage regulator be adjusted, or better to replace ?Dave0
You need to tweak the spring anchor for the voltage coil, and reduce the tension to cut the voltage back to 7.2 volts.0
Are you testing it with the new battery in? A bad battery may cause an overcharge.
If you have a new battery , then look at the online repair manual on how to adjust the voltage regulator.
Also check your ground wire connections at the generator and regulator. Make sure they are clean and tight and the wire is not broken.
New battery, will recheck all grounds then look into a regulator adjustment.Thanks GentlemenDave Eddie0
- 120 Hudson 1916 - 1929
- 612 Vehicles
