Hood Prop
YES ONE ON EACH SIDE THEY BOLT TO THE INNER FENDER ON ONE END AND THE HOOD ON THE OTHER0
Thanks mine wait till i have my head and shoulders under there then drop just enough so i hit my head coming out I will have to tighten them up. Or maybe lose a little weight so they dont get shook up so much. John0
Many, many a head have been got by a stepdown hood over the last 60+ years! Particularly the corners of the hood. I know some of the oldtimers used to open the hood and immediately put something like a cut tennis ball on the corners. Nothing like split heads to develop a little ingenuity!If your hood is dropping, then either you don't have the hood braces in, or they don't have the springs on the braces, or all of your springs are completely worn out. I don't believe I've seen a stepdown hood fall down before (not that it couldn't happen, of course).0
I HAVE A FEW SCARS FROM THE LENGENDARY HUDSON STEP/down HOOD CONNER ''OUCH'' WHEN YOU TALK ABOUT SAVING HUDSONS IT IS BLOOD SWEAT AND TEARS0
Studebaker Hawk hoods have to be the worst scalpers out there!0
The better idea for the hood prop is a REAL HOOD PROP. My short hood Hudsons all us solid metal rod to prop the hood open. Of course this does not keep me or anyone else from smacking the cranium on the corners of the hood.0
Don't forget the springs on the lower hinges (the hinge that bolts to the firewall),,that spring breaks. or gets week quite often..and puts more pressure on the side hood struts.
- 96 Essex Super 6
