FM converter
JFromm
edited August 2014 in HUDSON
Anyone have a source for a six volt positive ground FM converter?
  • Worse comes to worse, buy an old 12 volt one at a yard sale and get a 6 to 12 volt inverter.  Or so I've been told!
  • John, I have one. It's NOS. No instructions but dosen't look like it was ever used.
  • Here is another option gives you more options for what you can play through your stock radio:
  • Rediscover radio produces a product called a RediRad, which broadcasts an am signal to your 6 volt am radio using an input from an iPad / MP3 / CD player. Sounds like a great idea, however it will not work on my 52 Hudson with the OEM 6 volt positive grd radio. Went as far as to replace the unit, even tried it on another car 48 Chrysler,.....still will not work.
    I am not slamming the supplier so much, as he was quite helpfull, in the end he offered to refund my money.
    More I would like to know if anyone has been able to get one of these to work on  a 6 volt positve grd system?
    Dave Eddie
  • I got it to work in my '50.  However a couple of notes: 1) make sure you have it so it is switched off when the key is off.  I wired it direct as my radio is, an it burned out the relay inside the unit.  2) I got some capacitors from Steve Engel (HET radio guru) due to noise.  Steve has worked with Redicover and if you are having issues I would talk to him to get them worked out.
  • Hi Guys, Hate hijack the thread but I am unable to start a discussion on this forum , I type into the box but then its says need body of discussion and never loads after I type I the box. This is a hard forum for me for some reason to post. Can a mods post this new thread. thanks
    Convertible Cylinders REPO
    I am now a direct buyer of convertible cylinders for our stepdown Hudsons. I have corrected the issue with the door cylinders that were not able to come down all the way due to wrong length.
    The top cylinders, door and 1/4 window cylinders are $130 each plus shipping. These are cheaper than Hydro-Electric by $9 each and will fit correctly w/o modifications to the doors.
    Thanks
    Russ Maas, 21st Century Hudson 309-838-5551
    Thanks
  • Russ it is probably a browser corruption problem.  Use a different browser and see what happens.
  • Jon B
    edited August 2014
    Russ:
    Try reading this, about your "body is missing" problem:  http://openforum.hetclub.org/discussion/165430/wysiwyg-issue-body-is-required-#Item_1
    Also, in the future if you have problems or questions about how this forum works, try looking in the FORUM -- Instruction and tips category at the right.  There are often good tips there on how to run this thing.
