Any recommendations for a disc brake conversion for a 53 Hornet ?
briankarleyhotmailcouk
Hi, I am looking for a front disc brake conversion for a 1953
Hornet.
I am aware of the following sources of a brake kit
1. Matt Faust (via the forum)
2. www.abspowerbrake.com/
3. www.classicdiscbrakes.com/
Can anyone make a recommendation or share any experience of
having installed a brake kit from one of these, or other sources ?
Many thanks,
Brian.
This thread was moved to the "Street Rods" section.0
I recommend Matt Faust's Disc Conversion since I believe Matt used his own Hudson to perfect the System. The quality & machining of the Brackets & Hubs are excellent.
Choice #2 fit perfectly. There were no other club member kits available when I bought it, but it worked out OK. Used original spindle with no mods. Bolt on. If I had the choice, though, I would go with a club member.0
And pictures would be . . . ?0
Two of our chapter members installed disc brakes.
View the installation and supplier information on the
kit in our newsletter.
http://south-texas-hudson.org/index_files/April 2014 Vo l 4 Issue 4_ South Texas Newsletter.pdf
. Did you get their master cylinder? I' m curious about that. Do they supply a parts cross reference? I want to match calipers front and rear.
I ended up getting the electric power booster kit which comes with a frame mount MC that fit a standard MC bracket as advertised in WTN. Not cheap. Yes, they gave me a list of replacement parts (rotors, etc) for the asking.0
- 97 Essex Super 6
